Hey Guys,
I have my 1999 F-250 SD Reg. Cab Long Bed. After a moderate to hard rain here in PA, I get water in the cab under the door sill plate (the door step). I think it is coming from my rear window. I have the 3 pc. rear window and I think that the passenger side seal might be leaking but I can't find where. Anybody else have a similar problem - and if so, how did you fix it?
You can leak-check it by spraying a foaming glass cleaner all around the window on the outside and using air hose, blow all around the inside and have somebody watch for the air bubbles, then seal it with urethane. Or just have a auto glass shop take care of it.
