Advance trac warning
Old Dec 2, 2004 | 07:44 AM
now_exowner's Avatar
now_exowner
Yesterday, my wife called to say the info center was telling her to check the advance trac system and the indicator light was on the dash. We had high winds here (gusts to 55mph) and she said that she caught a really good gust about the time it came on. We only have 550 miles on it and have never had the advance trac. After she shut it down (at the direction of her all knowing husband!?!?!) the condition cleared and no repeats for the rest of the day. Has anyone had this problem or am I on an island??? Thanks
Dave
Old Dec 2, 2004 | 10:13 AM
daveplot's Avatar
daveplot
I had my check advance trac light come on for no reason before, luckly while I was on my way to my dealer for an appointment. They pulled a code and had to recalibrate the system.
I would say if the light comes on again to go into the dealer.
Old Dec 2, 2004 | 10:34 AM
jasonj734's Avatar
jasonj734
Had the same thing happen once on my Explorer, only happend once so I just forgot about it. Happened about 10,000 miles ago.
Old Dec 2, 2004 | 04:16 PM
Mattias's Avatar
Mattias
Happened on mine a few times too. Once I happened to be taking it into the shop anyways and they just reset it. The other times, it just went away itself (???)
Old Dec 3, 2004 | 04:21 PM
now_exowner
Thanks for the reponse folks, I'll keep my eye on it and keep you posted if something else goes on.
Dave
Old Dec 27, 2004 | 10:17 PM
MIKE1646's Avatar
MIKE1646
Mine did it only once and it was on a dirt road
Old Aug 4, 2012 | 08:56 PM
EchoEv1's Avatar
EchoEv1
My battery died and now my AdvanceTrac turns off when I start my 2005 Explorer. I'm concerned with going to the dealer to reset. I don't want them to charge me out the you know what. Does anyone know how to reset the advance trac or how much Ford Dealerships charge to reset.
Old Oct 28, 2012 | 09:15 PM
EchoEv1's Avatar
EchoEv1
Does anyone know anything about the advance trac warning light. My battery died and now advance trac shuts off when car is started and the warning light is on.
Old Oct 29, 2012 | 07:41 AM
c_hohensee's Avatar
c_hohensee
You will need to get a the code pulled. This requires a scan tool that can read chassis codes. Usually at the dealer or somewhere that has a dealer type scan tool. There are alot of parts involved with the system. On the wifes 03 Explorer it required reloading the as-built info into the abs controller after a new clock spring was installed to correct steering angle fault.
Truckie256
2009 - 2014 F150
Mar 26, 2015 12:27 AM
vtdave
New Member Introductions
Oct 12, 2013 09:48 PM
dwilliamsceg
Sep 8, 2009 07:04 PM
CWWatson
Jan 19, 2006 08:03 AM
