Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
staples
Old Dec 2, 2004 | 03:58 AM
ford390gashog's Avatar
ford390gashog
staples
would 3/16'' staples work in a bostitch 7/32 stapler it is only a .5/16'' difference are the 3/16'' smaller crown
Old Dec 2, 2004 | 05:30 AM
sinclair's Avatar
sinclair
No. I assume you are asking about the air gun you just puchased. They will not slide in tha magazine properly causing jams. you would think 1/64 of an inch wouldn't make a difference but it does. Your best bet is to use bostich staples as even generic brands designed for that gun dont perform as well Good luck with the new toys.
Old Dec 2, 2004 | 10:51 AM
ford390gashog
thanks i knew i should ask first i found 25,000 paslode staples on ebay for 3.00 the 7/32 for 5,000 is almost 22.00
