1978 - 1996 Big Bronco
Speedometer & Tach problems
Old Dec 1, 2004 | 10:11 PM
rafe1269's Avatar
rafe1269
I have a 82 bronco, speedometer and tach no longer work. Any suggestions?
Old Dec 2, 2004 | 03:22 PM
greystreak92's Avatar
greystreak92
They are completely separate so the problem is multi-part. Speedo on an 82 should require no electricity save for the illumination. I'd be looking at cable first and the connections at the back of thew gauge and the side of the transmission.
The tach is fed through the dark green/yellow wire running from the electronic ignition module and into the printed circuit card in the dashboard. Don't know ANYTHING about the printed circuit or how to test it but someone might.
