fuel pumps
Old Dec 1, 2004 | 07:15 PM
Lucky Charms's Avatar
Lucky Charms
Question fuel pumps
Hey folks,
I have a 87 ranger 2.9 L with a two fuel pump system. If the HP Fuel pump is not working does it mean the one in the tank will not work also?
Matt
Old Dec 2, 2004 | 11:32 AM
loudfords's Avatar
loudfords
If there is a problem in the wiring harness, then likely both pumps won't work. If the problem is within the HP pump itself, than the tank pump should still work, but obviously won't provide enough pressure for the engine to run.
Old Dec 2, 2004 | 05:48 PM
Lucky Charms
Red face
Thank you! I will try changing the Hp pump this weekend.
Matt
