Windshield wiper motor problem
Old Dec 1, 2004 | 06:45 PM
Bigcello's Avatar
Bigcello
Cool Windshield wiper motor problem
I'm having a problem with the passenger side wiper it will not work at all need help to fixing the problem.
Last edited by Bigcello; Dec 1, 2004 at 06:46 PM. Reason: spelling and adding endings
Old Dec 1, 2004 | 10:30 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
At the bottom of the wiper arm is a little plastic cover that goes over the nut that holds the arm to the shaft. Pop the little cover off and then turn on the wipers. You'll be able to see if the shaft that the wiper arm attaches to is turning back and forth or not. If it is you can probably just tighten up the nut. If the shaft isn't moving then the linkage under the cowl trim panel has broken of fallen apart.
