tires
Old Dec 1, 2004 | 04:11 PM
DMAN's Avatar
DMAN
tires
My friend gave me two tires for my truck they are 265-75-16 I was going to buy four more for the back and put these on the front but I can't find a 265-16 any narrower. The 75 will never work for the duals I can't even get my fingers between them. Is there a tire that is close to the 265 that is narrower that wont effect the gear ratio. The truck is a 4x4. I would but them on if I wasn't hualing a load but theres no way there not going to rub hualing 4 or 5000 pounds. Thank you for the help.
Old Dec 1, 2004 | 06:41 PM
inflatablepets's Avatar
inflatablepets
How about 235 75/85 16's.
Old Dec 1, 2004 | 06:43 PM
82F100SWB's Avatar
82F100SWB
235/85's are the same height, and narrower. They should be useable for a dually application.
Old Dec 1, 2004 | 07:03 PM
inflatablepets
I am pretty sure that's the correct size he needs.
Old Dec 2, 2004 | 05:16 AM
RR4E's Avatar
RR4E
They work just fine(275/85/16's) I ran them on a one ton dually cube van for a few years when I was a courier driver, and they gave the added height I wanted, without the rubbing sidewall problem. I haled closer to 8000 lbs in the truck and never had a problem, with heavier than stock springs and heavy sidewall tires.
Old Dec 2, 2004 | 05:33 AM
Torque1st's Avatar
Torque1st
Posting Legend
235/85R16's are a common size and will be the same diameter as your 265/75R16's.
You can check out tire sizes and RPM's (Revolutions Per Mile) at many tire company websites.
The first number in a tire size is the section width of the tire at the widest point in MM's the second number is the % of the section width that is the height of the tire.
Some quick calculations:
For a 235/85R16:
235 / 25.4 = W (width in inches)
(W x .85 x 2) +16" = Diameter
Therefore:
235/85R16 => 235mm (9.25") wide and 31.7" in diameter
265/75R16 => 265mm (10.43") wide and 31.6" in diameter
IslandBlueV10
Nov 8, 2011 12:19 PM
nightskyisme
May 7, 2007 09:08 PM
lovemy150's
18
Sep 28, 2006 08:36 PM
lllateralus
1997 - 2003 F150
Apr 21, 2005 03:01 PM
iknowitall
Ford vs The Competition
Jun 5, 2001 11:16 PM
