Got any pix of them and do they still have the connectors/mounting hardware? And just because I'm ****, that's $125 + shipping for the both of them??? Thanks for the quick reply.
I'm a Gomer sometimes, also what about the controller switch. Does it come with it? Where does it mount, if it's with the window control panel on the door and if our colors match, can we swap panels? I'm really pushing my luck, aren't I??? Even if we don't swap (I understand about that), I'd still like to know where they have the switch at.
I should have included that before they do not have the connectors you will just have to cut the connectors off your old mirrors and use them.That is what i had to do for the 04-05 mirror swap and i can get some pics if you wanna see em.
How did you wire the lights up? Is there a wiring harness there already that Ford did not use until 2003?
I would like to add some lighted mirrors to mine but was concerned about havint to pull the door apart.
Fire Rooster
Getting the door panels off is a five minute job, it's super easy. On the lighted mirrors, the wire colors match up for the mirror controls, so all you have to do is tap into the park lights and turn signal wires and a keyed hot for the mirror heaters. Not really all that difficult.
I've posted the wire colors and where to find them several times in the last year or so. I'll see if i can find you a link.
I've been doing some searches and following links around to find how to remove the door panels but haven't had any luck. Would you lead me to the right link? Thanx.
Cookie88,
could you please send me the first thread link that you put in post #8 on 8-10-04. First link, I get error...I got the second one which shows pic of your truck. Or better yet , if you remember color of turn siginal wires in sterring colum...they just bolt up where original is...parking light off headlight sw, turn lights & what about a why could I not put in a switch for the heaters off keyed hot? Do you know how much the heaters draw, much or not much at all? Don't want to get too much running off the park light wire on the headlight switch. THANKS
