Engine timing
Old Nov 30, 2004 | 06:17 PM
lumax's Avatar
lumax
Engine timing
My son just swapped out an enline 6 for a 351 modified V8 in his 4wd 79 ford. Does anyone know what the timing should be.
Old Dec 1, 2004 | 12:39 AM
hdgapeach's Avatar
hdgapeach
Most generally start with a base timing set at ten degrees advanced. I set my initial timing using a vacuum guage and set it at the highest vacuum at idle, then use a timing light to see where it is for reference.
