Changing from 1999 to 2001 engine
Old Nov 30, 2004 | 12:24 PM
nelgin's Avatar
nelgin
Bought a 99 in August, found out the engine is bad-compression test (the hightest reading was 360 and the lowest was 150 psi). Can I put a 2001 engine in it? Will I have to change wiring harness, pcm, idm? anything else?
By the way the site has been a great help. I can usually find answers without posting. I did do a search but didn't find anything. This is an early 99 f250.
Thanks
