96 air box
Old Nov 30, 2004 | 11:24 AM
wormslinger's Avatar
wormslinger
96 air box
does anyone know wher4e to buy a oem air box? I gave mine a little shot of starting fluid and it go bang. Broke it into little peices. Thanks
Old Nov 30, 2004 | 12:20 PM
Max1775's Avatar
Max1775
I have a complete stock air intake off of my 97 F250 (replaced with a K&N FIPK). Really don't have a need for it anymore so drop me a line if you want it.
Old Nov 30, 2004 | 04:58 PM
Ggg6's Avatar
Ggg6
Well, blowing up your airbox is probably a blessing in disguise. It is without a doubt the WORST DESIGNED air box ever. There have been recalls and design updates to it and it still sucks. They do not seal well to the filter element, no matter what brand filter, thus causing the engine to become "dusted". Do your truck a favor and buy a good aftermarket filter/intake setup Shop around for price they vary quite a bit. On the other hand you got what you deserve using starting fluid to start a turbo diesel. NEVER use starting fluid especially on a turbo diesel. You will be lucky if you have not done damage to your turbo as well, not to mention toasted what was left of the glow plugs. I have also seen first hand that explosion brake the g/p tips off and then they got embedded into the piston and lead to a cracked piston.
