Lowboy Height
Old Nov 30, 2004 | 09:54 AM
lowboy250's Avatar
lowboy250
Lowboy Height
I'm looking for input from all of the lowboy owners out there. Could you give me a measurement from the center of the front hub to the top of the front fender? I need to know how much lift my truck has in it and I can't find any specs on ride height. Thanks!!
Old Nov 30, 2004 | 04:53 PM
jnyreb69's Avatar
jnyreb69
On my 79 the measurement from the ground to the bottom of the front axle bump stop was 22". with a $' lift kit and 33"s its now 27 1/2"
Old Dec 2, 2004 | 10:29 AM
lowboy250's Avatar
lowboy250
What tire size was on the truck when it measured 22"? Also, what lift kit did you install, how do you like it, and how soft does it ride? Thanks.
Old Dec 4, 2004 | 07:06 PM
jnyreb69's Avatar
jnyreb69
the original tires were 9.50 x 16.5"'s. I put on a 4" rough country suspension lift system. It rides quite a bit rougher than stock and larger tires don't handle as good in snow and ice. In my opinion all you gain lifting a truck is good looks and bogging improvements at the sacrifice of everyday driveability. Also the lift kits have no provisions for altering your swaybars. I had to fab my own brackets.
