Sponsored by: Real Truck
tranny question
Old Nov 30, 2004 | 02:38 AM
Mrgeoff's Avatar
Mrgeoff
Exclamation tranny question
I can slightly hear a High pitch chattering/crackling noise coming from my tranny on my 94 F-250 with E4OD, 2WD with 125000 miles. It happens when i get about 90% to full throttle at any speed or gear. It has a good positive shift and doesn't ever slip, Its got no hesitation, shaking, or chatter. I scanned for codes, none were found. The fluid was still red and no burnt smell before I changed filter/fluid reciently. It had no shavings, just normal metal dust was wiped off magnet.
Old Nov 30, 2004 | 07:35 AM
Big Orn's Avatar
Big Orn
Check the tranny mounts, exhaust brackets, dust cover, and even the muffler/cat converter to see if they are loose. Sometimes a "chirp" can be metal against metal at a certain RPM.
Old Nov 30, 2004 | 12:37 PM
Mrgeoff's Avatar
Mrgeoff
you dont think its the tranny. it happens continously with the full throttle, any rpm, any gear.
Old Nov 30, 2004 | 01:05 PM
Big Orn's Avatar
Big Orn
I'm not ruling out the tranny. I just replied given your remark:
You said nothing about RPM's.
I'll give it more thought, now.
