sending unit
Old Nov 29, 2004 | 05:43 PM
ddbuggins's Avatar
ddbuggins
Post sending unit
where is the oil pressure sending unit on 92 f-150 4x4? how do i check efficiancy of unit. I have Low oil pressure?
Old Nov 29, 2004 | 06:07 PM
mooktank's Avatar
mooktank
right near the oil filter
Old Dec 1, 2004 | 10:32 AM
ddbuggins's Avatar
ddbuggins
should I pull it and clean up the wires ground them to the frame and flip the key? Or should I just get another? Also Truck only has 64,000 original miles on it. But I do work it hard in the winter. Also hav a poor ground someplace any one have suggestions on where to start? Checked battery grounds OK.... Starter ground appears loose and was tightend up . I run a older western Plow off it also. THe plow motor has been benched tested .Could it be the plow sylinoid? Improper ground there? I will try that but if anyone has other suggestions please post. Thanks ALL
Old Dec 1, 2004 | 10:52 AM
bigbluebronco43's Avatar
bigbluebronco43
Why don't you start by telling us whats wrong with your truck. Is it reading low oil pressure or something?
Old Dec 1, 2004 | 12:17 PM
andym's Avatar
andym
It would also help to know what motor is in the truck.
Old Dec 1, 2004 | 02:00 PM
bigbluebronco43
Thats better. Now just post what andym told you to post up.
Old Dec 2, 2004 | 09:56 AM
ddbuggins's Avatar
ddbuggins
its a 92 f-150 4x4, It's Reading low oil pressure on dash. I have changed the oil and filter. I thought I mentioned low oil pressure in my first note . anyway thats it. I also must have a bad ground on my plow some place. Thanks for any help
