Need Transmission help
Old Nov 29, 2004 | 04:13 PM
MT69highboy's Avatar
MT69highboy
Unhappy Need Transmission help
I have a 73 F250 4x4 that the front bearing retainer is broken. I am pretty sure it is a New Process transmission because there is a NP stamped on the top. Does anyone know where I can get another one?
Old Nov 29, 2004 | 06:30 PM
andym's Avatar
andym
If it's a four speed with a granny low, it's probably an NP 435. Best place to get one is in a junkyard, as the tranny was discontinued in the late 80's/early 90's. If you can, find out what truck it came out of if it's separate. Different trucks sometimes had different ratios. Also, input and output shaft dimensions can vary from chevies to dodges to fords.
Of course, if you find another '73 F-250 4x4, you can be pretty sure it'll fit.
Take a look at: http://www.novak-adapt.com/knowledge/np435.htm
Old Dec 2, 2004 | 10:51 AM
MT69highboy
Thanks for the information. I learned a lot about my transmission and they had a kit if I need to rebuild the tranny.
