Aerostar Ford Aerostar
Airbag 3-2 code
Old Nov 29, 2004 | 02:36 PM
92aeroXLT's Avatar
92aeroXLT
Airbag 3-2 code
I just had 2 front tires replaced and aligned, etc.. which stopped that terrible vibration, but is there anything that the mechanics may have bumped to cause the 3-2 code while driving.. I still have horn and cruise use.. and the recall has already been done on the clockspring. Any help would be great thanks!
Old Nov 29, 2004 | 07:50 PM
92aeroXLT's Avatar
92aeroXLT
this is a continuation .. also when I turn off the car there is a beep that comes from the dash!! Any ideas??
thanks~!
Old Nov 29, 2004 | 08:34 PM
pfogle's Avatar
pfogle
Make sure that the sensors on the frame and bumper are plugged in. Also 32 is the clock spring circuit, and the beeps is a power fail in the module. Check fuses for sure.
Old Nov 29, 2004 | 10:19 PM
wettone's Avatar
wettone
Broke the shifter tube on my 92-3.0L shortie. Removed the column and replaced the tube. Was getting a A/B light code before the fix. After, no more code, lamp test works on start up. But I wouldn't reccomend it. Sorry, not any help, but a peculiar story just the same.
Old Nov 29, 2004 | 10:35 PM
92aeroXLT's Avatar
92aeroXLT
how many sensors are there on the frame and bumper??
Old Nov 29, 2004 | 11:33 PM
pfogle's Avatar
pfogle
There should be one behind the bumper, one on the passenger side frame rail behind the tire, and one in the dash.
Old Nov 29, 2004 | 11:40 PM
92aeroXLT's Avatar
92aeroXLT
so it's possible that when the put the new tires on they bumped the sensor?
