Fuel gauge died
Old Jan 12, 2002 | 10:33 AM
xriverrunner's Avatar
xriverrunner
Fuel gauge died
The fuel gauge stopped working on my 1996 Ranger XLT. Can't find any blown fuses or loose wires. Is this a common problem and is there a chance that it might be corrected without going into the fuel tank? Thanks for any information.
Old Jan 12, 2002 | 03:24 PM
Ken00's Avatar
Ken00
Fuel gauge died
You can test sendor by measuring the resistance, 160 ohms full, around 10 empty. You can test the gauge the same way using resistors in place of the sendor, give it a minute or two for it to read accurate. If you have to replace the sendor, which is part of the pump, pull the bed off, it's easier than trying to drop the tank.
Old Jan 12, 2002 | 08:38 PM
xriverrunner
Fuel gauge died
Thought this might be about what I would have to do. Will probably continue to use the tripometer rather than do a major repair job. Thanks for the info.
Old Jan 12, 2002 | 08:59 PM
J_91's Avatar
J_91
Post Fuel gauge died
Does this go for a '91 as well?
Old Jan 13, 2002 | 04:44 PM
Ken00's Avatar
Ken00
Fuel gauge died
The full resistance on the older ones is 73 ohms, same for empty.
Old Jan 13, 2002 | 06:59 PM
Ken00's Avatar
Ken00
Fuel gauge died
Scratch that I was thinking a different sendor. It's 160 for full.
Old Jan 14, 2002 | 01:53 AM
MyBj's Avatar
MyBj
Fuel gauge died
