Poly Gas tanks
Old Nov 29, 2004 | 08:00 AM
Sicko's Avatar
Sicko
Question Poly Gas tanks
Anyone here ever used a poly gas tank? If so are they durable. The gas tank on my 83' F250 has a rust problem inside the tank that causes me to change filters constantly. I appreceiate any info.. Also is 127.95 a good price for a 19gal rear tank?
Thanks, PJ
Old Nov 29, 2004 | 09:04 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
I haven't used one but I can't see the downside. The poly tank should be as strong as the steel one without the rust issues. It stays out of the sun so you wont have any UV issues either. Don't know if the price is right, you'll just have to compare on line.
Old Nov 29, 2004 | 09:40 AM
F250Wildman's Avatar
F250Wildman
advance auto parts has a new one for $106. online
Old Nov 29, 2004 | 10:24 AM
Sicko's Avatar
Sicko
The tank that is 106.88 is a metal one right? Or did you find a poly tank?
Old Nov 29, 2004 | 11:29 AM
wiseguy's Avatar
wiseguy
I've had one on my '86 for about three years now. The only problem I had was when I installed the sending unit, I didn't tighten the hold down wcrews tight enough, and it leaked. I called the company, and they tole me that the hold down screws would break before the plastic did, and they sent me a new sealing ring. I installed the new ring with some Permatex, and tightened the screws nice and tight. No leaks, no problem. Bought my tank from J.C. Whitney.
Old Nov 29, 2004 | 12:27 PM
Sicko's Avatar
Sicko
I checked out J.C. Whitney and they wanted 176.95 . I was wondering what causes the tank to rust inside ; arent they coated with something? I have found a new metal tank for 96.00$. What are the chances of that tank rusting like the other one?
Thanks for the patience/replies
PJ
Old Nov 29, 2004 | 12:53 PM
1982fordf100's Avatar
1982fordf100
Jeff's bronco graveyard has them. They are $120 for a plastic tank. http://broncograveyard.com/products/cat/20/257/30233
Old Nov 29, 2004 | 08:52 PM
boflaade's Avatar
boflaade
PJ
Tanks rust! I don't think they are coated but how long do you plan on keeping the truck? The tank you are replacing lasted 21 years and 21 years from now you may not even have the truck.
Old Nov 30, 2004 | 05:49 AM
wiseguy's Avatar
wiseguy
I had always heard that condensation on the inside of the tank was the cause of rust. I never paid much attention to it until the day I was under my truck and looked at the tank. The temperature had changed that day, and there was a heavy layer of condensation all over the outside of the tank from the bottom to the top of the fuel level. If there's that much condensation on the outside, then you know it''s forming inside also.
Old Nov 30, 2004 | 06:13 AM
Sicko's Avatar
Sicko
I never looked at it that way . He!! I think I will just go with the metal one. Thanks to all who replied.
laters,
PJ
Old Nov 30, 2004 | 11:04 AM
F250Wildman
Galvenized metal looks like original and they also have the intank fuel pumps
Old Nov 30, 2004 | 11:29 AM
Sicko's Avatar
Sicko
Wildman250 do you have a link to that Galvenized tank you were talking about??
Old Nov 30, 2004 | 01:54 PM
F250Wildman
advanceautoparts.com
Old Nov 30, 2004 | 07:24 PM
Yoshi's Avatar
Yoshi
I haven't really known many tanks NOT to rust on these old trucks. My front one is leaking all over the place. Luckily she runs on propane.
Old Nov 30, 2004 | 07:26 PM
Yoshi's Avatar
Yoshi
We have an 88' Diesel Super Duty that has a leaky front tank as well. You have to fill it up every 150 miles.
