temperature fluctuating
Old Dec 1, 2004 | 12:54 AM
Popa Tim's Avatar
Popa Tim
I don't have this pronblem on my truck, but I used to have a car that would do this a few times a year and the fix was to turn the timing back to spec.
Hmmm.. funny but now that I think about it, that car was a Ford too! LOL
Popa Tim
Old Dec 1, 2004 | 06:26 PM
cbr900's Avatar
cbr900
On older cars there used to be a voltage stabilizer that kept all the gauges working correctly, I dont know if 1990 or later models have this item, maybe ford mechanic knows, I know on an old car I had this item went bad a caused the gauges to fluctuate.
Old Dec 1, 2004 | 06:57 PM
nick150's Avatar
nick150
well i looked into the voltage regulator for the gauge even though i know the actual temp is fluctuating. the 95 f150 does not have one in it. the only voltage regulator is in the alternator. went to autozone, had them test it in the truck then pulled it out and had them test it on the bench. both times passed no problem.
now the confusing part. drove the truck 35 miles this morning, did not fluctuate. half way home, it started to fluctuate again and has all afternoon up till now. any thoughts on why the temp fix?
thank you. you guys are great.
Old Dec 1, 2004 | 09:45 PM
ATC_250SX's Avatar
ATC_250SX
Did you check hoses?? i mentioned it before, and it is something that would cause your situation. they would only collapse when the pump is turning faster, causing more circulation.
Old Dec 2, 2004 | 12:56 AM
texan2004's Avatar
texan2004
Check the hoses
I agree with ATC. Hoses with age will collapse and could certainly cause this problem.
Old Dec 2, 2004 | 10:02 AM
nick150's Avatar
nick150
the hoses seemed pretty firm when i removed them to replace the rad. and water pump. i do not think the lower hose has a metal spring in it and i know the upper does not. could i get the truck warm and rev it to see if the hose collapse or does the amount of load on the engine effect the hoses collapse?
thank guys for all of the help.
Old Dec 2, 2004 | 10:19 AM
Bluffer's Avatar
Bluffer
Could be the guage itself. try a aftermarket temp gauge,
Old Dec 2, 2004 | 04:38 PM
ATC_250SX's Avatar
ATC_250SX
no it wouldent, just speed of the pump. because of the increased circulation.
Old Dec 2, 2004 | 04:45 PM
cbr900's Avatar
cbr900
now this is strange because the top hose on my 1991 f150 5.0 collapses after it has been run and turned off, then expands again when started up from cold but I don't have any trouble with the gauges, I think it must be pulling a vacuum in the system when shut down, but has not yet caused any problems and runs fine otherwise.
Old Dec 2, 2004 | 05:46 PM
nick150's Avatar
nick150
cbr, sounds to me from what i know that the overflow tube is kinked or blocked up or the cap is not working properly. when the coolant heats up, it expands, once it builds up enough pressure, the cep sends some coolant to the overflow tank. when the system cools, the coolant "contracts" and it sucks back coolant from the overflow to replace the coolant that was sent to the overflow tank. id check the rad cap and the over flow tube.
ill try reving up the motor when it is hot and see if the bottum hose collapses or not.
thanks again for all of the help.
Old Dec 2, 2004 | 09:35 PM
ATC_250SX's Avatar
ATC_250SX
it amy be just like someone said and you may have a head gaskey on the worng side, however the head gaskets dont care what side there on, someone above stated they did, but i know with my 5.8 it wouldent take much at all to plug a passage at the head gasket, there only maby 1/4 inch hole if that, id defidently flush it my self or bring it somewhere like jiffy luber or something and have it done.
Old Dec 2, 2004 | 10:16 PM
nick150's Avatar
nick150
i dont think it is the head gasket because ive had the truck for 40k miles and it has never done this before. also this afternoon, on the way home i stopped by autozone and pressure tested the cooling system and cap. cap opend right up at 13lbs and the system held 14lbs for about 4 mins till i took it off. i thought if the cooling system held pressure, the head gaskets were good.
i did notice when i installed the old temp sensor, the gauge hangs a little liower, near the "N" in normal and still fluctuates, but it is not as much on the gauge. however, i think it is just the difference between the new and old(partially broken) temp sending unit.
thanks again for all of the help, i cant wait to get to the bottum of this.
Old Dec 20, 2004 | 01:26 AM
  #28
TriumphBoy's Avatar
TriumphBoy
Temperatures
Any way to check the temp. without using stock guages? Maybe set up external temp guage and run the wire through the window while driving?
Sounds like your guages are lying.
Old Dec 20, 2004 | 02:25 AM
  #29
buzzer's Avatar
buzzer
Check all your engine/battery grounds that go to the body in the engine compartment. There may be as many as 4 ground straps in the engine compartment. Since you indicate other cluster problems it most likely is a ground problem. If that does not sure your problem It may be in the cluster as the cluster has diodes and most likely a voltage reducer built into it. Check e-bay as i have seen dash clusters there very reasonable. You can put your speedo into the other cluster if the milage is off a great percentage on the replacement cluster.--PS--CHANGE ALL THE HOSES you may have an internal collapse even if you do not see it from the outside. I have delt with these problems before.
Ron1999
1997 - 2003 F150
Jul 1, 2015 12:19 PM
areyou4real
Aerostar
13
Jan 17, 2015 07:59 PM
pizzadahutt
1983 - 2012 Ranger & B-Series
Jan 5, 2011 06:20 PM
pullt1
1997 - 2003 F150
Jan 3, 2007 04:21 PM
Doctor E
Feb 8, 2004 07:59 AM
