Offroad & 4x4
What to do
Old Nov 28, 2004 | 01:52 PM
fordmandiesel's Avatar
fordmandiesel
Question What to do
I Want To Buy A 96 F-150 To Make Into An Off-road Monster. I Want To Put In A Hi Performance 5.8l With About 420 Hp. I Have Everything Writen Down On Paper What I Want To Put On It To Make It Everything That Ive Dreamed Of. My Question Is, What Would I Need To Do To It To Make The Truck More Durable With The Suspension And Drive Train? If You Want To, Add Me To Your Msn Messenger And Messeage Me That You Want To Reply To My Thread. Thank You
Old Nov 28, 2004 | 02:49 PM
monsterbaby's Avatar
monsterbaby
well personally if you don't already have the truck (which I assume by your statement wanting to buy a truck) then find a 96 2wd with a good body. then go buy a 70s era 3/4, or single wheel 1 ton 4x4, and swap bodies that will give you a good strong running gear, and is cheaper, and easier to lift. Next forget the 351, nad drop in a 514 or so stroker with around 600+hp. but thats just me, I like body swaps, and lotsa hp to start with cause you will be updating for more latter anyhow.
Old Nov 28, 2004 | 11:08 PM
fordmandiesel
Im Taking A 66 2wd And Putting It On An 80 1/2 Ton Frame And Jacking It Up With A 514. Does That Sound Good
Old Nov 28, 2004 | 11:24 PM
monsterbaby
sounds good witht he exception I would go with the older style frames for the solid front axle but your talking now with body swap and the big block.
