Should I Install a Pyrometer
Old Nov 28, 2004 | 11:55 AM
John with beastly 302's Avatar
Hey we'll be getting our new 05 F-350 XLT 4X4 Dually Diesel soon and I was pondering if it would be wise to install a pyrometer. If so were should you mount it before the turbo or after the turbo, how about having two gauges a post turbo and a pre turbo?
The truck will be used for towing and hauling a camper and 3 horse trailer. I know it already has a boost gauge I just hope it's not a switch.
Thanks John
Old Nov 28, 2004 | 12:08 PM
Daryl Hunter's Avatar
Daryl Hunter
I installed a pyro preturbo on my '03 to monitor temps while towing my 30' toyhauler. Truck and trailer together are usually in the 18,000 lb range give or take a few hundred.
Towing around SoCal, up and over the Grapevine, Cahon pass, and out East over the continental divide it never got up into the unsafe range - max was 1173 deg F as I recall.
I use the X-Monitor which has pyro, tranny, and boost all in one. It allows you to keep the driver's pillar handle too which is nice. It also has a flashing alarm if you exceed your preset threshold, and keeps track of the last max value since reset.
If your truck is going to remain stock and not have a tuner added, you probably don't really need a pyro gauge but it sure is nice to have. The tranny gauge is nice too because the stock gauge is just an analog idiot light.
Old Nov 28, 2004 | 12:19 PM
jasfaa's Avatar
jasfaa
I think it is good to have one. Especially when towing over mountains and having your foot on the pedal for an extended amount of time. You are probably safe without one if you are stock though IMO.
Old Nov 28, 2004 | 12:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am the one that never has enough gauges, be good to have one pre-turbo, post turbo, one before the CAT one in the CAT one after the CAT one before...well prolly too many now
Old Nov 28, 2004 | 01:24 PM
04powrstrokr550's Avatar
04powrstrokr550
tim, all you need now is a gauge in the combustion chamber, one in each cylionder...
Old Nov 28, 2004 | 01:34 PM
dazedandconfused's Avatar
dazedandconfused
Put one in preturbo, especially if you plan on putting a chip in it at any time!
Old Nov 28, 2004 | 03:24 PM
pappy42's Avatar
pappy42
I always hear of the danger of the probe breaking off and going through the turbo, on pre turbo installations. Has anyone actually had this happen, or know anyone that it has happened to?
Old Nov 28, 2004 | 03:26 PM
jasonschwenk's Avatar
jasonschwenk
Question
at what temp do you have to worry if you mount one in pre-turbo?
also how do you rectify it if you reach a high temp? just slow down?
Old Nov 28, 2004 | 05:15 PM
IB Tim's Avatar
IB Tim
Of all the FTE members I know and all others (non members) that are runnig probes..never once have I know it has happened.
I know guys that have had the same probe in 7.3's with 250k on them....
so...you OK.
Old Nov 28, 2004 | 09:30 PM
dazedandconfused
You are always suppose to mount them preturbo. You are safe up to 1300* and you can go above that for short periods of time. You usually only have to worry about this once you start bombing them. Free flowing intake, straight pipe 4" or bigger are the easiest. If you put in bigger injectors you have to go with a bigger turbo or NOS!
Old Nov 28, 2004 | 10:57 PM
jasfaa's Avatar
jasfaa
so...you OK.
I have heard that the people that have broken off a pre turbo pyrometer it has been caused by the piston breaking up in the cylinder and exiting through the exhaust that causes it to break. At that point and time you have a lot more issues to worry about than worrying about a turbo. Just kidding, no one has ever posted in this forum or any other that one has broken off and caused turbo damage. It is possible to damage it if installation is done incorrectly but this is never been proven in my time owning a diesel and since I have been in this forum.
Old Nov 29, 2004 | 04:59 AM
t_j82's Avatar
t_j82
The old probes were made of different materiel than the new ones so melting used to be an issue. Now, from what I understand they are made of stainless steel and melting is no longer a problem. I have yet to see,hear or read of anyone that has had a newer probe cause any problems with the turbo.
Old Nov 29, 2004 | 09:58 AM
jasfaa's Avatar
jasfaa
That is what I was saying too only if the engine blows up and goes through the exhaust system will it break off. I for got to add my little smiley face
