warning chime
Old Nov 28, 2004 | 11:03 AM
donaldora's Avatar
donaldora
warning chime
where is warning chime located on 1996 windstar?
Old Nov 29, 2004 | 09:58 AM
stepman's Avatar
stepman
Can you clarify that? Do you mean the part that actually makes the sound? Are you having a problem with it?
Old Nov 29, 2004 | 10:34 AM
donaldora's Avatar
donaldora
Yes. The chime itself. It goes off intermittentently and I would like to completely silence it without affecting anything else. I looked for it, but could not find it.
Old Nov 30, 2004 | 08:17 AM
stepman's Avatar
stepman
Not exactly sure about that. Somewhere near the fuseblock I think. The chime going off by itself though is usually because the wire broke the attaches to the key cylinder. You can cut the wire to silence it if you want. If you pull the shroud from around the column you will see it. Black wire ( I think)with a small plastic piece, when the plastic breaks, it grounds and sets off the chime. If you cut it, it will need a new clockspring to replace it.
