Oil Flow in Filter
Old Nov 27, 2004 | 10:20 PM
HDCarl's Avatar
HDCarl
Oil Flow in Filter
What is the direction of flow through the oil filter in the 6.0 PSD? I want to install the Pre-Luber oil pump and need to know if I feed the oil back into the filter cap will the oil be going through the filter or bypassing it?
Thanx in advance
HDCarl
Old Nov 28, 2004 | 12:04 AM
3/4ER's Avatar
3/4ER
I beleive the direction of flow would be out of cap, thats how the OILGUARD by-pass filter works. The return on this set-up is to the oil fill cap on the valve cover.
The older style set-up used a return line to a special oil drain plug, in the oil pan. I beleive PRE-LUBER uses the same style drain plug in their set-up.
Thanx in advance
HDCarl
Old Nov 28, 2004 | 08:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You are correct, that is the flow direction.
Old Nov 28, 2004 | 08:31 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Doesnt the 6.0 hold the oil up in the motor when its off? or is that not as much as a pre-oiler would do?
