Help Tranny Probs
Old Nov 27, 2004 | 02:34 PM
lenbo06776's Avatar
lenbo06776
Cool Help Tranny Probs
HELP my c-6 wont move I parked the truck about 1 month ago (cuz it aint registered yet)and haven't started it since i went out wed.eve and tried to move it and it dont move any help will be great. oh its a 88 f-250 7.3
Old Nov 27, 2004 | 06:23 PM
rancherman84's Avatar
rancherman84
check the fliud level?,linkage moving okay?
Old Nov 27, 2004 | 07:55 PM
Al_V's Avatar
Al_V
Does the whole truck shake when you rev the engine trying to move it?
Old Nov 27, 2004 | 08:03 PM
PLC7.3's Avatar
PLC7.3
Not a 4x4 with the transfer case in nuetral..............
Old Nov 28, 2004 | 08:01 AM
pnose's Avatar
pnose
What about the vac pump.dont the C6 need vac to operate??
Old Nov 28, 2004 | 08:06 AM
Al_V's Avatar
Al_V
That would not stop it from moving the truck at all.
Old Nov 28, 2004 | 08:24 AM
lenbo06776's Avatar
lenbo06776
tranny probs
linkage is all hooked up fluid level good transfer case in 2hi
Old Nov 28, 2004 | 08:38 AM
PLC7.3's Avatar
PLC7.3
I have heard that due to slight misalignment/wear in the transfer case the unit is not quite in the selected position. Suggest you do several selections between 2wd and 4wd etc. Other thought would be pranksters did not block up the hack end?? did they.
Old Dec 19, 2004 | 11:21 AM
lenbo06776's Avatar
lenbo06776
i dropped the tranny pan today and found a small plastic piece that looks like a plunger anyone ever seen this before?
Old Dec 20, 2004 | 09:08 AM
csramsey640's Avatar
csramsey640
yes that plunger is a factory plug during installation. Finding this plug in the trans, means the tranny fluid has never been changed, unless someone didnt remove that plug. even new vehicles use that plug
