window regulator handel
Old Nov 27, 2004 | 12:36 PM
Ian Mike B's Avatar
Ian Mike B
I cant get the pin out of my 50 F-3 window regulator handel. Any sugestions
Old Nov 27, 2004 | 02:09 PM
Jet Jock's Avatar
Jet Jock
You can drill it if all else fails. The one on my truck were epoxyed on....Previous owner needs .......kicked. Melted mine off.
Jet Jock
Old Nov 27, 2004 | 02:31 PM
f1fordguy's Avatar
f1fordguy
Try a nail punch. Worked great for me. It was just the right diameter to catch the top edge of the pin. The pins are hollow so a nail will just wedge the thing in there if the point goes inside the pin.
Hope this helps.
Tim
Old Nov 27, 2004 | 03:13 PM
Ian Mike B's Avatar
Ian Mike B
Feeling stupit
Thanks for the advice, took another look and discovered that there are two holes for pins and I had been putting my punch in the empty one and pounding against the shaft. The pin was flush with the outside of the handle and was solid not rolled type. Tapped on it and it came right out. Oh well, live and learn, alls well that ends well and all that good stuff. THANKS again
