Anybody with an MSD Box?
I replaced my spark plug this weekend with a set of Motorcraft 42 plugs . I read on the MSD web site to run a larger gap, so i set them at .50 I notice a lot more power at lower rpms(MSD is not much help above 3000)
Has anybody else played around with this setup?
Thanks, MudKat66
,86 2.9L Auto K&N, MSD 6A, free Floating Rockers arms, Taylor Spiro-pro 8mm wires, Intake Spacers, Ported TB.
Thanks, MudKat66
Yeah I've got the MSD 6a box, coil and wires. I never noticed any more power no matter what I did, It did run a little bit smoother with the box but it dropped my mileage about 3 mpg. I started with some platinum plugs gapped at stock than moved them up to the msd specs with no avail, diconnected the box and mileage got better than I got regular autolite plugs gapped at Ford spec hooked the box up, nothing, MSD specs still nothing so then I disconnected the box, left the plugs at MSD specs and got the same mileage and power that I had before MSD. Did you get any better mileage when you put your box in that was the main reason that I bought mine?Travis
Flatheadv8
*87 ranger STX
2.9, K&N cone, Magnaflow, MSD, Flex-a-lite electric fan
31x10.50 BFG Mud terrains
15x8 Eagle 117's
6" skyjacker
Sikkens silver metallic
Ford grillgaurd, rollbar (off), tubular rear bumper all powdercoated gloss black
Delta crossbed toolbox
Clarion deck/rears, alpine fronts,
Rocford Fosgate-punch 100, punch 250,and 10"XLC
Hella FF100 fog lights
Flatheadv8
*87 ranger STX
15x8 Eagle 117's
6" skyjacker
