what is involved?
Old Nov 25, 2004 | 11:57 PM
dhag911's Avatar
dhag911
what is involved?
what is involved with installing electric gauges on my 1992 150 302. i am wanting to get a trans temp, oil temp, and tach. i am wanting to install them on the a pillar. or i guess if above the radio is a lot easier that might be an option too. the will be 2 1/16" or 2 5/8"
is there drilling involved?
what kind of difficulty? I am pretty mechanical inclined dad is a mechanic if i need help.
i guess what is all involved with wireing these?
if anybody has pics of these let me know. how dumb do you think it would look if i used different kinds of gauges?
Old Nov 26, 2004 | 01:06 AM
andym's Avatar
andym
Hmm. Electric gauges, huh? Any reason why you don't want to use mechanical ones?
You'll have to drill a hole through the firewall to pass the lines. Various other drilling might need to take place.
You're going to have to drill a hole in the tranny to install the sender for the temp gauge. Where to install it depends on the tranny you have.
The oil temp gauge will be very tricky. There's no 'standard' place for it, and you can't use the oil pressure location. You'll have to drill and tap into the block.
As for the tach, you may want to look into swapping in a factory gauge cluster with a tach. Much easier to install.
