Replacing Transmission
Old Nov 25, 2004 | 09:54 PM
IluvDonuts's Avatar
IluvDonuts
Ok, I drive a 1992 F-150 5.0L V8 Auto, and i want to swap the auto tranny (which isnt in great shape now) with a 5 speed manual any suggestions? and please dont say, just dont do it, this truck has sentimental value or else i would just find a stock manual truck.
Old Nov 26, 2004 | 06:28 AM
woodzracer's Avatar
woodzracer
Thumbs up Replacing Transmission
No one should ever tell what to do or not to do to your truck! The question is is it a worthwhile swap. My advice would be to look around for a similar parts truck so you will have everything you need and an idea of how it goes together. I bought a parts truck that was hit in the front for $200 because my truck needed a tranny, and I ended up with a spare 302, 8.8 rear, glass, 4 new tires and the list goes on. Just look around and see if it is a viable idea.
Old Nov 26, 2004 | 10:19 AM
MustangGT221's Avatar
MustangGT221
Well, first you've got to see if you have an E4OD tranny, it's computer controlled and would need modifications to the computer in order to work. If it's an AOD or C6 or one of those (not computer controlled), than you're all set as far as computer issues.
The main areas of concern are installing the clutch master cylinder and the pedals. The brake pedal will also need to be swapped because the Auto's is wider. I think that is where you'll have the most trouble. Other things, like driveshaft length, and crossmember, are items that can be swapped out easily. The column will need to be swapped...but it would be kinda funny ot have the auto shifter on the column, and the 5 spd shifter on the floor. Might confuse a few people
My best advice is to get a donor
Old Nov 26, 2004 | 11:43 AM
IluvDonuts's Avatar
IluvDonuts
thanks bunches guys, i really appreciate you no telling me "dont do it..." Ill check around at local tranny shops and in junkyards. yet again thanks bunches.
Old Nov 26, 2004 | 02:54 PM
t_dickie's Avatar
t_dickie
I had both gearshifts in a truck for a while. The auto was just my "turbo" option!!
Trevor
Old Nov 26, 2004 | 03:21 PM
couleeman's Avatar
couleeman
The little things are alot of work, but it can be done. The best thing, as has already been said, find a whole truck and so you not only have all the parts, but you have something to look at as well for the little things.
It is to bad you didn't little closer cause I could set you up with the whole works.
Old Nov 27, 2004 | 12:52 PM
IluvDonuts's Avatar
IluvDonuts
heh, wish i did live closer, thx neway tho. Any opinions on dropping a 7.5L in it, should i do it at the same time as the tranny or does it matter which order i do it in.
Old Dec 11, 2004 | 04:49 PM
faroffthetrack's Avatar
faroffthetrack
Hey just wondering if you've done the swap yet, how'd it work out?
