Is there any way to reset the check engine light besides actually fixing the problem?I've unhooked the battery but it only stays off for a couple of hours.
If the light keeps coming back on after you've left the battery disconnected for at least five minutes you should get the error code scanned. It's a recurring code.
Sid
You may be surprised that the code could be something simple to fix. I know they are anoying but if you just unhook the light or something, the problem (or problem perceived by the computer) will still be there. This could effect the way your vehicle runs because the computer will be making an adjustment for the perceived prob.
Hi to everyone, 4.0 Ford explorer 4x4....couple of days ago CEL came on. Code reader indicates P0230, " Fuel Pump Primary circuit malfunction ". Any hints on how to pimp point the problem.?? Is it fuel pump ( I hope not...). Yr prompt suggestion will be highly appreciated as I am In Venezuela, S.A and things down here are not as easy to solve as in the U.S
Bruce, I didn't see in your profile what vehicle you have. IF there are no faults reporting to the computer on a "first generation" EEC, the CEL will reset with the battery disconnected for a few minutes.
With second generation EEC's (some 1995's and 1996 and newer), the check engine light will reset after 3 complete drive cycles as long as there are no faults on the computer. Each manufacturer will define a "drive cycle" a little differently. Otherwise, it takes a code reader or scan tool to reset the light. If there are no faults reporting to the computer, it's memory will hold the fault for 40 drive cycles for maintenance recall if needed. The light will not be illuminated in this condition.
I'm not an auto mechanic, and this is my understanding on how it works based on my limited experience, but if your light remains on, this is an indication that you have a "real time" fault, no matter which system you have. There is lots of documentation on reading codes and troubleshooting procedures per the codes you get. I would suggest getting to the root of the problem if your light is on. Remember, "downstream" sensors may be reported as bad, when something else is causing the problem...eg; rich mixture may cause an oxygen sensor fault.
I'm new here with a 98 Explorer XLT 5.0 AWD. I was wondering WHERE I could geta list of the "codes" if I need to trobleshoot a code? Thanks...Mike
Welcome to the only family Ford Truck site, on the net.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE and Happy Holidays
At least go to a Ford dealer and have them decode ypur system,and give you a detailed fault reading and repair estimate. You don't have to repair it there. It's a$100 wellspent and them you can decide what you want to do,repair it your self or let them do it.
