Radiator overflow problem
Old Nov 25, 2004 | 07:51 AM
firegod619's Avatar
firegod619
Thumbs down Radiator overflow problem
Hello all,
Does anyone know how to solve the problem of the radiator over flowing through the cap after you use your programmer.
Old Nov 25, 2004 | 08:26 AM
bighoss550's Avatar
bighoss550
Originally Posted by firegod619
Hello all,
it does it without the tuner too. mine really stinks unless i turn on the water inj. with the water, it never overflows.
i kinda wonder if the exhaust is gettin hot enuf to boil the coolant in the egr cooler tubes.
Old Nov 25, 2004 | 09:09 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
I suspect that...
Oddly enough, mine boils with the EGR plugged in, and does not with it disconnected.
Old Nov 25, 2004 | 06:16 PM
bighoss550's Avatar
bighoss550
Originally Posted by PSD 60L Fx4
I suspect that...
do u have to disconnect it with the engine off and the key off? or does it not matter? mine boils with it disconnected, and dont know about when it is connected cuz it doesnt get reconnected
Old Nov 25, 2004 | 08:24 PM
eharman's Avatar
eharman
I wish I could help you. I only use the 45 hp and the 65 hp modes. I have no coolant lose here.
EJ
Old Nov 25, 2004 | 10:10 PM
SBV45's Avatar
SBV45
There is reports of this happening without the Predator while pulling heavy loads uphill. Coolant should show at the Min level on the degas bottle. If you unplug the EGR, unplug it with the key off. Normal closed. Make sure the system is keeping pressure.
Old Nov 26, 2004 | 12:00 AM
Z-MAN's Avatar
Z-MAN
I Have Noticed Overflow Too, I 'am Running The Banks Six-gun Bundle I Noticed When I Let The Truck Idle For Extended Times Or When I Try To Let The Turbo Cool Down After A Long Trip
Old Nov 26, 2004 | 12:05 AM
Z-MAN's Avatar
Z-MAN
Hey bighoss550 greatings and happy turkey day, any problems with the h20 inj. what system are you running, and for what purpose lowering egt's when towing or strickley for the extra ponies, what kind of numbers does the system put out for you.
thanks Z-MAN
