transmission problems
Old Nov 24, 2004 | 10:41 PM
chefandy1st's Avatar
chefandy1st
need help. just had my transmission rebuilt 6 monts ago. Now the overdrive switch is flashing and the tachometer is going crazy and the transmission is shifting really hard. I have a 1991 F350 diesel with an automatic transmission and overdrive
Old Nov 25, 2004 | 09:30 AM
RANCHHAND's Avatar
RANCHHAND
I would just take to who ever rebuilt it and have them check it out. It sounds like it could be your tach sensor that is mounted on the injector pumps timing cover.
Old Nov 25, 2004 | 09:53 AM
motovert2001's Avatar
motovert2001
some tach sensors are on the alternater.
Old Nov 25, 2004 | 11:46 AM
PLC7.3's Avatar
PLC7.3
Your tach is causing the trans to go into Limp Mode a safety feature so the trans does not destroy itself. Check the wires just where they exit the sensor, quite often they will have the plastic shielding pulled back and touch each other due to fan air flow. Check the connector at the sensor harness and the engine harness connector at the drivers fender.
