check your battery
Old Feb 11, 2002 | 07:48 PM
rellik74's Avatar
rellik74
check your battery
Check your battery I just had a $ 49 battery FRY a $160 alternator, these new ones are small and can not run a ranger when the battery goes dead.
Old Feb 12, 2002 | 06:15 PM
red ranger's Avatar
red ranger
check your battery
what brand and what size was it that caused the damage....was it a mistake on the numbers for your truck or ???
Old Feb 12, 2002 | 07:03 PM
rellik74's Avatar
rellik74
check your battery
No the battery was old 5 years it went dead on the way home about 12 miles and in the process it killed the alt. It is a normal problem with the new type of alt, the are much smaller that the old style and can not put out a high enough charge to run the truck alone.
Old Feb 13, 2002 | 12:44 PM
Ken00's Avatar
Ken00
check your battery
Old Feb 13, 2002 | 02:44 PM
brg_ranger's Avatar
brg_ranger
check your battery
I'm not sure where you heard that the alt can not run the truck alone, but you have been misinformed. The alt MUST have MORE than enough output to run the truck because it also has to charge the battery after starting. What really happened is that your alt died on the way home (very common), and the truck was forced to run off the battery (which killed the battery).
