radio reception ?
Old Nov 24, 2004 | 12:28 PM
slifer's Avatar
slifer
radio reception ?
Does anyone have any tips on how to improve fm radio reception? I can only get in a couple stations at work, and its driving me nuts. I work in a large steel building, I think that is my problem. Anyone know anything about amplified antennas? Radioshack has one for like $30 but I don't know if it'd help or not. Any suggestions would be appreciated, thanks.
Old Nov 24, 2004 | 12:33 PM
Power Hungry's Avatar
Power Hungry
Former Vendor
I guess you dont have cable tv at work, if so get a splitter and connect the end of the coax to yer fm antena
Old Nov 25, 2004 | 12:51 AM
nightowl_52's Avatar
nightowl_52
You don't say what type of antenna is on that radio. Is it a pull up type, a wire hanging out the back, or a terminal on the back to hook a external antenna to. Whichever it is you could try running a wire from the antenna and touch it to the metal of the building or stick it in the round ground hole of a wall socket or try and find one of those little gizmos you plug in the wall and hook a tv antenna wire to that uses the house wiring as a antenna. If none of that works in that steel building, then get a tape or cd player.
Old Nov 25, 2004 | 01:25 AM
rywegh's Avatar
rywegh
how good a radio do you have. THe best reception for am/fm radios I have found so far comes from a philips radio. I work in a warehouse that has all kinds of steel and wire in it.
Old Nov 25, 2004 | 01:45 AM
wezol5484's Avatar
wezol5484
Thats what I was gonna say, use the whole building as an antenna. Should work in theory.
Old Nov 25, 2004 | 04:12 AM
Crash687's Avatar
Crash687
Whichever it is you could try running a wire from the antenna and touch it to the metal of the building or stick it in the round ground hole of a wall socket.
it is code that building steel is to be grounded to earth and the electrical system ground. it makes the whole building into sort of giant sheilded wire. sheilded wire is use when protection from EMI is needed. EMI= electromagnetic interferance= radio waves.
need to get the antenna on the roof.
Bruker
18
Dec 18, 2006 10:02 PM
roushracing617
Nov 14, 2005 08:43 AM
Bruker
18
Mar 27, 2005 04:49 PM
Power Hungry
Nov 8, 2004 03:21 PM
