What causes a plugged Cat?
I always idle the truck at higher RPM's (with AIC) to prevent this and keep the engine temp up. 3 other co-workers also drive the truck and a couple don't engauge the high idle. Last week the truck was exhibiting the low power again and the check engine light was on. I suspected a plugged cat. I engauged the high idle at about 1700 RPM for a few hours to heat the cat. I them drove it down the road. In Drive (auto tranny) the truck would max out at 17 MPH and not exceed 2100 RPM. It didn't feel like it was shift out of about 2nd gear. If I manually put it in 3rd I could barely make 35 MPH at about 3000 RPM. I drove it back and forth a 1/2 mile section of road to blow out the build-up. After about 2 trips up and down the road, performance was back to normal, but the check engine light was still on. Re-started the truck and CEL was still on. Idled the truck at 1500 RPMS while parked. CEL went off about 1/2 a day later. Every thing seems back to normal again.
I want to nicely inform my co-workers of the importance of utilizing the high idle. I would also like to inform them of why the cat is plugging off. Is it because of unburnt fuel accumulating in the cat when the cat is not warm enough to burn off the unburnt fuel? Or is it blowby oil accumulation in a cold cat? I doubt it is engine oil because the oil level remains constant.
My supervisor is looking into a Cat delete pipe. These are private roads, so I think we are exempt from federal highway requirements. They may be concerned about warranty issues with the local dealer involving a Cat delete though.
....................HP..................
