new Cam Sensor just went bad?
I have a 95 powerstroke, took the old cam sensor out, replaced it with a new one....
....about 400 miles later....it is acting up again. It runs, but barely. Could I have installed the sensor in the wrong position?
It ran great and then all of a sudden it just started acting up. I can shut it off and let it sit for a minute, then it will run good for about half a mile then start running bad again. Could there be a loose ground?
I replaced the sensor with the original ford part # F6TZ-12KO73-A........
but I have another new one # F7TZ-12KO73.....Is this part compatible with the 95?
My DTC codes are :Exhaust Pres Cntrl valve range/perf
:Camshaft Pos Sensor Circuit Intermittent(bank1/1 Sens)
:Camshaft Pos Sensor Circuit Error
:Internal Ctrl Mod KAM Error
HELP!
THANKS!!!!!!!!!
HELP!
THANKS!!!!!!!!!
