Exahust Leak
Old Nov 23, 2004 | 12:09 PM
rufaast's Avatar
rufaast
Exahust Leak
Question: Under Acceleration(harder Than Normal) Towing Or Not, I Hear An Exhaust Leak, Looked Around The Down Pipe Connection Didnt See Any Smoot. Did See Smoot On The Wastegate Valve Arm That Hangs On The Bottom Side Of The Exhaust Housing. V-band Clamp On Downpipe Is Tight.
I Have Also Looked Around The Exhaust Manifolds And Didnt See Any Leaks?
Any One Have Any Suggestions Where It Might Be Coming From, Is It Normal To See Smoot On This Wastegate/bypass Arm? Can It Be Stopped If This Is The Location Of The Leak.
The Sound, Sounds Like A Leaking Manifold, Exactly Like That, But Like I Said No Indication Of That Happening.
Any Help?
