Ranger odometer noise
Old Feb 11, 2002 | 10:54 AM
Robk1013's Avatar
Robk1013
Does anyone know how to fix a noisy odometer in a 94 ranger.
Old Feb 11, 2002 | 02:14 PM
94ranger's Avatar
94ranger
I have a noise problem too. It is really bad when it is cold out I would also appreciate any sugestions on how to fix the problem.
Old Feb 12, 2002 | 10:30 AM
JohnBon's Avatar
JohnBon
Same Problem..94 Ranger
Old Feb 13, 2002 | 08:15 PM
vivitar151's Avatar
vivitar151
Same promblem in my 94 Ranger
Old Feb 17, 2002 | 12:22 AM
dzk007's Avatar
dzk007
:-X23 Hey guys, I believe you all own the last year of the mechanical speedo. If so, pull the instrument cluster and disconnect the speedo cable. dump some ATF down the inside of the cable. be liberal with it. reassemble it and test drive immediatly.
should do the trick
Old Feb 24, 2002 | 01:00 PM
robk1013M's Avatar
robk1013M
Thanks for the information..what is atf
Old Feb 24, 2002 | 01:26 PM
Avanti's Avatar
Avanti
Had the same problem on a Crown Victoria back when they had cable driven spedos. The factory manual recommends silicon grease. It does not harm rubber.So I bought a tube of Sil Glyde from NAPA. Worked great, fixed the problem. Also use on many other areas that are rear rubber, brakes, cotact points. etc
Old Feb 24, 2002 | 08:10 PM
Hank85713's Avatar
Hank85713
