engine dies when warm
Old Nov 22, 2004 | 01:26 PM
Nadi's Avatar
Nadi
hi there,
my 302 2bb starts up great when it is cold. the choke does it's work. as soon the part of the choke is done, i mean the fast idle is over, my van dies every time i drive very slow or at a stop sign. when the engine dies, there comes a very loud hissing sound from the carb, right in the middle where the choke plate is located. it sounds to me it gets to much air.
the problem does not stop, even if i am driving an hour or so. it used to be a little diffent a couple weeks ago. back then the problem got better as soon the engine warmed up after 10min driving.
fuel pump? any stupid emission device? i had the carb and all the little sucker around it replaced 2 years ago. my map sensor is new as well?
any ideas?
Old Nov 25, 2004 | 10:20 AM
LxMan1's Avatar
LxMan1
You have a large vacuum leak. Look for missing or broken(cracked) vacuum lines. If not, could be the carb gasket is bad. You can spray a little carb cleaner around the carb when it's running to find the leak. The idle will change when you spray it.
Just don't spray the distributor or plug wires. Could cause a fire.
Old Nov 25, 2004 | 02:37 PM
Nadi's Avatar
Nadi
o.k. i'll check it out right after t-day.
the carb gasket is new. it was changed with the carb about 2 years ago.
thanks
Old Nov 25, 2004 | 11:55 PM
Nadi's Avatar
Nadi
hey,
guess what, i found the problem. there is just one thing that keeps buggin me:
behind the carb is a metal cylinder with a lot of hoses coming in. one port had only some leftover from a vacuum hose on it. so i was looking for the other end of a hose flying around the carb. could not find anything. so i just plugged the port with a rubber cap and the hissing sound was over and the van rides smooth.
could it be, that there wasn't a hose in the first place, just a plug that got rotten over time??
anyway? thanks a lot and take care
Old Nov 26, 2004 | 09:10 AM
LxMan1's Avatar
LxMan1
That is possible, The end might have dryrotted off.
Glad you got it fixed
