Trans. fluid change
Old Nov 22, 2004 | 12:43 PM
mike L's Avatar
mike L
Trans. fluid change
Hi guys, I have a 87 f150 4.9 with a NP 435 4 speed manual trans. 140,000 miles on the org fluid. Its getting harder to shift, when stopped. I want to replace the trans fluid, to see if it helps. Can I use those qt size plastic bottles that you squeeze? Will I be able to get to the fill hole with these bottles or will I need to use a hand pump with a small length of clear hose? Is there a brand I should try, since it got higher milage? I think it takes SAE 80W. I think it holds 7 qts.
Thank guys
Mike
Old Nov 22, 2004 | 02:40 PM
guzzler96's Avatar
guzzler96
Lightbulb
I think you can purchase a fill tube, clear plastic, that screws on top of a quart bottle. I got one at Autozone. Pretty cheap. If its anything like my '90, I had plenty of room to use the clear plastic fill tube on the qt. bottle. I also pumped it out once and back in with a hand pump. Either work just as well. Its probably a little easier for me 'cause mine takes Dexron III auto. trans fluid and is a little thinner.
guzzler96
Old Nov 22, 2004 | 02:56 PM
blu's Avatar
blu
I pull the shifter out to fill through the cab takes about fifteen minutes to take the shifter out. Don't know if its easier or harder doing it this way I just know I make a mess when pouring things.
Old Nov 22, 2004 | 07:17 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
When I was last in Maine for the winter my manual tranny did not want to shift on cold mornings. I changed to synthetic lube and it made a huge improvement. Make sure to get the correct lube for your tranny.
Old Nov 22, 2004 | 08:13 PM
mike L's Avatar
mike L
transmission oil change
thanks i think i will do that.
Old Nov 22, 2004 | 08:14 PM
mike L's Avatar
mike L
I'll look into it thanks
Old Nov 22, 2004 | 10:12 PM
t_dickie's Avatar
t_dickie
I don't know what is better to fill it, but it might take ATF. Probly not seeing is a NP, but I know the newer 5spd's take ATF. Gear oil gets too thick in winter. Just somethin to watch out for.
Trevor
Old Nov 22, 2004 | 10:15 PM
andym's Avatar
andym
The four speeds take gear oil, only the Mazda takes ATF. Not sure about the ZF.
Old Nov 22, 2004 | 10:17 PM
t_dickie's Avatar
t_dickie
Ok, I thought so, but figured it'd be worth pointing out. I don't know if they carried the ZF over into 97 and up, but a 97 with a 5spd takes ATF. But like I said, I don't know what tranny that is.
Trevor
06FUN
Oct 29, 2016 07:53 AM
bigcrunch
Jun 29, 2014 04:32 PM
SF58
1997 - 2003 F150
Feb 10, 2013 06:48 PM
Becca_78
1983 - 2012 Ranger & B-Series
Aug 13, 2009 04:58 PM
dunbar15
May 9, 2006 10:01 AM
