SOHC intake gasket replacement gone wrong - Help!
Old Nov 22, 2004 | 10:38 AM
bk_89ix's Avatar
bk_89ix
I replaced the upper/lower intake gaskets on my '97 SOHC V6 Explorer
today since I had been getting the usual warmup problems on cold
mornings. The procedure had already been performed several years ago
along with the timing chain tensioners.
The gasket replacement seemed to go smoothly, but now the car won't
idle for more than 20 seconds. I triple-checked all vacuum and
electrical connections and the battery was disconnected while I
performed the work. I was very careful to get all the mating surfaces
clean and to tighten things evenly. The IAC valve is new and is
plugged in.
I installed the gaskets dry, since I couldn't find any info otherwise,
but I did notice that the upper gasket I removed had been packed with
white grease. The original lowers were coated with oil, which I
presume came from the intake.
Should I have coated any of the gaskets with grease, or do they get
installed dry? Any other suggestions??
Bob
(reposting from the Explorer board by suggestion)
Old Nov 27, 2004 | 12:50 PM
Blly177's Avatar
Blly177
did you disconnect the battery to reset the computer after you did this
Old Nov 27, 2004 | 01:14 PM
bk_89ix's Avatar
bk_89ix
I saw that awesome writeup after I did mine! Anyway, I got confirmation that the gaskets all go in DRY so that part was fine. During some of the followup troubleshooting I replaced the PCV valve (dealer had provided the wrong one), replaced the intake boot and also confirmed continuity and connection order of the newly installed ignition wires. I still don't know what the main issue was, but it's now running perfectly. I've got a couple hundred miles on it and all is well, especially cold warmups!!
Bob
chrisPi
May 27, 2012 09:05 PM
jexplorer
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 3, 2006 10:57 AM
Bobz
Jan 31, 2004 11:26 PM
purplegoat
36
Nov 13, 2002 01:13 AM
