Sponsored by: Real Truck
ABS question
Old Nov 22, 2004 | 09:33 AM
mopnup's Avatar
mopnup
ABS question
I recently completed a lift and tire swap. I have an 03 F-250, V-10, Edge 6" lift and Weld 20 x 10 Cheyenne 8 with Nitto 37 x 13.5 mud grappler tires. I also used SDHQ exteded kevlar brake lines with the lift. I have driven the truck for a week and today the abs light is on. What might be causing this and is there a solution. Thanks you for your help. And by the way everything you read on here about Donahoe susp is true. My truck rides much better than stock.
Old Nov 22, 2004 | 02:15 PM
etcetera's Avatar
etcetera
Could be a speed sensor is out, or a cable got mangled. One on the rear axle, it sits on top of the diff and reads the ring gear speed. One on each front tire.
