Flooring for Bed
Old Nov 22, 2004 | 07:33 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Flooring for Bed
Anybody here ever see a truck with Tongue and Groove flooring ran side to side? I am pondering this just to be different. It will not be a work truck so I am not worried about scratching the bed up to much. I put down green treated 2x8's lumber for now. Maybe oak, maple, cherry or IPE?
Old Nov 22, 2004 | 11:31 AM
51dueller's Avatar
51dueller
I've never seen a pickup with it but I have redid a grain truck box floor with it. It works fine but you may have to hand pick the boards your gonna use as several of the ones we got were slightly warped which made reassembly a little tough. Also they may need a little wood working to get the seams perfect. Also you probally could make your own with a router.
Old Nov 22, 2004 | 12:05 PM
Christopher2
Veteran: Navy
I have the tools for doing a wood floor so a small warp can be taken out with a floor nailer. I did a 1" wide maple floor in a spare bedroom I built. I would have to hand pick like you said because I would want each board to go from side to side no short pieces.
Old Nov 22, 2004 | 12:17 PM
51dueller's Avatar
51dueller
The boards we had were 2"x6"x15'.
Old Nov 22, 2004 | 12:19 PM
Huntsman's Avatar
Huntsman
Humidity will be your worst enemy, as it is with any hardwood flooring. Your floor will buckle or raise up at the joints as it collects moisture. The flooring system in these old trucks, is designed so that there is a gap between the boards for expansion and contraction. It would look good, but only practicle if there was a way to seal or encapsulate the floor.
Old Nov 22, 2004 | 12:21 PM
Christopher2
Veteran: Navy
These would be 1.5 x 1 x approximatle 54"
Old Nov 22, 2004 | 12:24 PM
Christopher2
Veteran: Navy
Good point, maybe I could use boards like are used for decking. Heck I could use the same type of composite decking I used on my deck. It is still in good shape after 5 years and I have not had to do any maintenace. It is designed to be used outside.
Old Nov 22, 2004 | 12:28 PM
Sore Knuckles's Avatar
Sore Knuckles
I recall an old thread which addressed the tounge and groove design. It presented the same problem that Huntsman mentioned here. There is no room for expansion of the wet wood. If I recall correctly, someone actually had the expanded wood push out their bedsides.
Clarence
Old Nov 22, 2004 | 12:30 PM
Jag Red 54's Avatar
Jag Red 54
I would think that the boards would raise and buckle unless they were afixed to a sheet of plywood underneth. Also, on past threads on this subject. the idea of water getting into the groove portion seemed like a deal breaker. You can't seal in the groove, or the tongue portion for that matter, and the water would get in and rot the wood in short order. John
Old Nov 22, 2004 | 03:27 PM
fatfenders's Avatar
fatfenders
Thats how my truck was when I first bought it. It was swolled enough to push the bedsides into the tires, and tore the seam out where the bedside meets the extensions. Wood is powerful when it decides to move.
Old Nov 22, 2004 | 07:55 PM
56 Effie Aurea's Avatar
56 Effie Aurea
Chris, I concur with all about the potential problems. My bed has t&g from the previous owner and they are buckled like crazy. Since I keep a tonneau on it's not a priority of mine right now (plus I haul my chairs, my umbrella, my cooler, my grill, my tv, my swimming pool, etc. when I go to car shows). My plan is to one day cut one of the black cherries out back on the farm and have it milled for my bed and go with the stainless strips between. Seen a lot of oak and pine on trucks but never one done in cherry wood.
Norb
Old Nov 22, 2004 | 08:34 PM
Christopher2
Veteran: Navy
That is why I am trying to find something different. I never was one to be like everyone else. I don't want the oak bed. The decking boards are sounding better.
Old Nov 22, 2004 | 08:46 PM
fatfenders's Avatar
fatfenders
"Seen a lot of oak and pine on trucks but never one done in cherry wood.
Norb"
Do it Norb. I have seen a few and it looks outstanding.
Old Nov 22, 2004 | 09:57 PM
sgtrwg's Avatar
sgtrwg
Hey Norb
There was a blue 54 F-100 in Marlette this summer with cherry used in the bed. It looked awsome....
Don't remember the guys name but I do recall he said he lived somewhere near by.
bob G
Old Nov 22, 2004 | 10:18 PM
Delzell's Avatar
Delzell
I'm new to this Forum so the reply is late. I would use Ipe,Teak or if you want to get supper fancy a wood called Goncolo Alves available at Hardwood suppliers. Toungue and groove would cause problems unless you leave room for expansion. I'm thinking of using Ipe but is very heavy. I may run 3/8" deep grooves on underside space about 3/8" apart to see if it lightens it any and may help control warpage. The old timers used to do that on the landings at exterior stairs on the campus where we use tounge and groove Douglas Fir. I would also think about what you want to put on it. You may want to use a Marine Grade tung oil from Mohawk Finishing Supplies. I think scratches would be easier to repair. My backgroung is cabinetmaking not mechanics. If I can be of any help let me know.
