Springs
Old Nov 21, 2004 | 09:48 PM
Val-01-CC-350's Avatar
Val-01-CC-350
Springs
Newby just trying to find the answer and have been unable in searching..
I read on a previous post that the door vin decribes the front spring code. My first 5 is 3FTX W...???? Is this enough info to find out my spring code and if so is it the 4th digit. X springs. My 01 has the droop and since a new set of tires (70k original) is in the works I was thinking about giving her a slight lift. Thanks in advance, Val
Old Nov 21, 2004 | 09:56 PM
Val-01-CC-350
Maybe I've had 1 to many but when I looked at my post it didn't mention tires prior to 70k, but when I go to edit I see the post is correct. Sorry for the double post. I'll check myself into rehab tomorrow or have my vision checked...
Old Nov 21, 2004 | 10:08 PM
realhp's Avatar
realhp
The X denotes 8600 GVWR. I would install a leveling kit I did and love the way it rides and handles.
Old Nov 21, 2004 | 10:28 PM
Val-01-CC-350
RealHP... Thanks. What kit did you go for if you don't mind me asking and where did you get it? Thanks, Val
Old Nov 21, 2004 | 11:23 PM
realhp's Avatar
realhp
I went to a local spring rebuild shop and they already had a kit put together that included an add a leaf u bolts and centering pins. I will call them tomorrow and ask them the name of the kit.
