General Automotive Discussion
Using two pcv valves
Old Nov 21, 2004 | 09:43 PM
fordguy21's Avatar
fordguy21
1996 windstar 3.8L
Is it good or is it bad to use two pcv vavles on the engine. One would go on the rear valve cover like normal, and the other would go on the front valve cover where the breather valve is.
Is this good or bad for the engine or pcv system.
Old Nov 21, 2004 | 09:47 PM
rusty70f100's Avatar
rusty70f100
It's bad. The breather is supposed to draw fresh air in, then the PCV is supposed to suck the crankcase vapors in for combustion. With two PCV valves, the blowby crankcase vapors will linger in the block and contribute to sludge.
Old Nov 22, 2004 | 04:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
Run one PCV only. They are calibrated to run as part of the induction system on your engine. With two valves hooked up like you said there would be no way to draw fresh air thru the engine which would lead to a buildup of contaminates.
Old Nov 22, 2004 | 04:32 PM
fordguy21's Avatar
fordguy21
Thinks guy glad I asked.
