air conditioner
Old Mar 6, 2002 | 05:09 PM
probation144's Avatar
probation144
air conditioner
how can i remove the factory radio need to check why air conditioner is not blowing out of the dash vents
Old Mar 6, 2002 | 07:43 PM
Ken00's Avatar
Ken00
air conditioner
You didn't say what year but most newer ones use a tool you can buy or just cut two pieces of coat hanger and push them in the holes on each side and pull out. The vent problem is most likely a vacuum motor or vacuum line problem.
Old Mar 6, 2002 | 10:11 PM
probation144
air conditioner
its a 1995
Old Mar 7, 2002 | 08:38 AM
Ken00's Avatar
Ken00
air conditioner
Take a look at the radio, you should see the two holes on each side. When you push the tool into them it releases the radio.
Old Mar 7, 2002 | 05:25 PM
aerocolorado's Avatar
aerocolorado
air conditioner
Wire size required is larger than coat hanger wire, something around a 10g size will work a lot easier. Just bend it into a U shape with approx. 5" legs. Copper ground wire will work fine.
Old Mar 7, 2002 | 05:37 PM
aerocolorado
air conditioner
