First start hard & smokes
Old Nov 21, 2004 | 05:22 PM
tscaud1's Avatar
tscaud1
When the truck has been sitting for a day, it doesn't want to start on the first crank. It tries to start on the 2nd with a ton of white smoke coming out the exhaust. Starts on the 3rd with more white smoke for about 5 seconds and runs and restarts perfect the rest of the day. Just started this 2 days ago. Never any start problems before.
Old Nov 21, 2004 | 05:44 PM
Ran440's Avatar
Ran440
tscaud1
Have you checked the glow plug relay yet?
Randy
Old Nov 21, 2004 | 05:47 PM
rirwin's Avatar
rirwin
Sounds like glow plugs not working. Put a test light on the big posts of the glowplug relay. One should be hot all the time and the other should be hot when the key is turned on.
Old Nov 21, 2004 | 05:59 PM
CAT_man_963's Avatar
CAT_man_963
Definitely sounds like a glowplug related problem. The glowplug relay and glow plugs themselves would be the first things to check. For the problem to start that suddenly like you describe - I would bet on the relay. I would imagine it unlikely, though possible, that all the glowplugs would go bad all at the same time.
Old Nov 21, 2004 | 07:00 PM
barebackjake's Avatar
barebackjake
im going for that gpr, check both big post and when key gets turned on check small post one should get power the other is ground. should hear it click when key comes on also. if you dont get power on one of the little post your problem is further back
Old Nov 21, 2004 | 07:12 PM
rirwin's Avatar
rirwin
Mine blew me away last week. It was clicking when key on making me think it was good, but had no power comming out.
Old Nov 27, 2004 | 05:38 PM
tscaud1's Avatar
tscaud1
results
Since its still under warranty and was in the dealer for other problems I let them know about it. They recalibrated the computer. Starts on the first turn now. Didn't like the answer. If the problems returns I'll update everyone
