front wheel bearing question
Old Nov 20, 2004 | 07:19 PM
Drool Monkey's Avatar
Drool Monkey
how do I remove the inside front wheel bearings?? I dont want to destroy the retainer.
Old Nov 20, 2004 | 07:22 PM
F150'89's Avatar
F150'89
It would help if we could know what you are working on.
Old Nov 20, 2004 | 08:03 PM
Drool Monkey
sorry. 1955 f100 ...damn egocentrism
Old Nov 20, 2004 | 10:07 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Remove the brake drum and tap the inside wheel bearing out from the inside.
Old Nov 20, 2004 | 10:33 PM
Overkill-F1's Avatar
Overkill-F1
Use a wooden dowel or a brass rod to tap them out like ranger pat says. Then you shouldn't damage the bearing or it's race. The seal will come out with the bearing. I would recommend you replace the seals, it isn't worth trying to reuse them. There're cheap enough. ...Terry
