Should I Replace Anything???
Old Nov 20, 2004 | 06:50 PM
DUALLYNOTED's Avatar
DUALLYNOTED
Smile Should I Replace Anything???
I know this is a rather broad question. I have a 2000 7.3 F350 Dually I bought in Feb of 2004. 51k mi now 61k. aside from the oil changes and fuel filter which i do, are there any other things that i can change as a preventive maintanance?
its not showing any signs of trouble and would like to keep it that way...The only thing I notice is when towing uphill with my 7000lb trailer it kinda makes a chugging sound through the air intake, Not loud but a constant even sound. Thanks
Old Nov 20, 2004 | 07:01 PM
Kwikkordead's Avatar
Kwikkordead
I would recommend changing out all the fluids on the truck. Transmission, transfer case, rear diff, front not so important unless you're in 4x4 most of the time. Coolant.
The noise coming out of the air intake: It's compressor stall and it's hard on the turbo. There are a few options to remedy that from $50.00 to $1000.00 and up from there. The $50.00 option is the way that I went and it cleared it up. It's called the Wicked Wheel or the Swisher Wheel. Basically it's the intake turbine from an early Powerstroke. At that price you have to install it yourself but if you are a decent wrench it's not hard at all, just tedious because you have to lay across the engine and work on the turbo, or pull the turbo out of the truck and replace it while on the bench. The other more expensive options are a Ball bearing turbo with a ported housing, etc.
Other issues that these trucks have is air in the fuel being introduced at the quick connects from the tank to the fuel pump inlet.
http://community.webshots.com/album/32614313yLKyrS/0
https://www.ford-trucks.com/forums/s...d.php?t=260173
Old Nov 20, 2004 | 07:06 PM
DUALLYNOTED
Thanks
Where Do I Find This Wheel????
Old Nov 20, 2004 | 07:13 PM
Kwikkordead
Well I checked with the sponsors of this web site and came up empty handed so I had to go to the competition. This link may not be around for long. You'll have to manually enter it too as you'll be redirected to Motorhaven, which I couldn't find a wicked wheel on thier site.
http://www.dieselsitetoo.com/index.asp?PageAction=VIEWPROD&ProdID=47
Old Nov 21, 2004 | 10:45 AM
bluemoose89's Avatar
bluemoose89
https://www.ford-trucks.com/forums/s...d.php?t=304219
here is a thread that might help a bit
