Sponsored by: Kumho
ball joint help
Old Nov 20, 2004 | 05:20 PM
mlh280's Avatar
mlh280
Question ball joint help
1999 ranger xlt 4x4 supercab
I know this topic has been done to death but I need alittle help! I have read alot of posts on this but I still would like a step by step on how to replace lowers and uppers. I have the parts and the ball joint press. I just need guidence. Haynes isn't much help either. PLEASE HELP
Old Nov 20, 2004 | 05:32 PM
SRD4X4's Avatar
SRD4X4
Jack-up under control arm,remove axle nut,un-plug ABS,remove caliper,remove pinch-bolt at top of knuckle(for upper balljoint),remove lower balljoint nut and seperate from knuckle,remove knuckle,remove snap-ring on top of lower balljoint,press out lower balljoint,reverse to assemble.
Old Nov 20, 2004 | 06:25 PM
mlh280's Avatar
mlh280
Thumbs up
Thank you very much that helps a whole lot. I'm going to try on monday to tackle it. Wish me luck
Old Nov 20, 2004 | 06:33 PM
SRD4X4's Avatar
SRD4X4
" IT'S ALL NUTS-N-BOLTS" You'll make it.
