4.2L engine swap
Old Nov 20, 2004 | 04:21 PM
cdawley4's Avatar
cdawley4
4.2L engine swap
Hi,
I have a 99 F-150 with a 4.2L V6. I just got the transmission rebuilt. I have also read in the transmission spotters guide to stay away from the 4r70w transmission on the V6. I have been thinking that when my V6 dies, I want to swap it for V8. Will the 4.6L V8 or any other V8 fit on my transmission? I am just curious right now and it is just a thought.
Thanks,
Chris
Old Nov 22, 2004 | 02:52 PM
stangboy_82's Avatar
stangboy_82
I've yet to try this with a 4.2 but from what I understand the 4.2 and 3.8 are just about the same motor and they use the same motor mounts, bellhousing, etc... so that means the 5.0 will bolt to your transmission.
Old Nov 22, 2004 | 06:33 PM
'961506's Avatar
'961506
I think the 4.2 is just a stroked 3.8. So, wouldnt that make the 4.6 bolt up, as the 5.0 is not made anymore.
Old Nov 22, 2004 | 11:26 PM
AlfredB1979's Avatar
AlfredB1979
Just get a wrecked 4.6 truck and grab what you need from that to make things easier.
Everything will bolt into your truck, being they are the same under the hood, just optioned differently.
If you go 5.4L, the whole chassis harness goes as well.
Old Nov 23, 2004 | 08:40 AM
stangboy_82
the 4.6 v8 is a different bell pattern then the 3.8 and 5.0 just throwing that out there
